-   -   electrical trouble (https://www.rctech.net/forum/radio-electronics/595952-electrical-trouble.html)
association 02-06-2012 05:44 AM
electrical trouble
so i just bought a team associated sc10 to help me have some fun on my deployment. its the rtr brushed version. i was rippin around the track we have on base and it was acting like the battery was dying. seemed rather quick so i brought it over and it stopped working. replaced the battery and still nothing. i can steer but the car wont go anywhere. even with a brandnew battery. my reciever wires are plugged in. i checked them. motor wires are good too. is my esc burned out?
hotrod87 02-06-2012 06:17 AM
Sounds like you may have lost the motor or the esc. Does the esc do anything when you turn it on ? Wich esc is it ?
hotrod87 02-06-2012 06:21 AM
Sorry just reread it for brushed not brushless.
association 02-06-2012 06:21 AM
its the xp sc200 that came with the truck. the lights on it come on when i turn the truck on but thats about it.when i hit the trigger on the radio the light shuts off too. just noticed that
hotrod87 02-06-2012 06:24 AM
Could be the motor you might unplugging one of the motor wires and use a voltmeter check for voltage when trying the throttle.
association 02-06-2012 08:54 AM
would it be the motor already? ive only had it for about a week. am i over looking something easy?
K1RC 02-06-2012 09:19 AM
Try resetting the esc too, it could even be something as simple as a stone jammed in the motor if its brushed. Hope you figure it out soon :)
nitro_mt_racer 02-06-2012 12:01 PM
My guess is that you've lost a brush in the motor. Look in the slot of the motor can and you should be able to see 2 copper bars with carbon brushes on the ends that contact the comm. You've probably got a brush off and the copper bar is laying directly on the comm.
chucko 02-06-2012 12:33 PM
Quick way to check if its the motor is... un plug everything... plug in the speed control to the steering in the receiver, if the motor works with steering the speed control needs to be reset. push that little red button on the switch. if it don't work plugging it into the receiver then the motor is messed up. hope this helps.. keep your head down bro...
