Tekin RS
hey guys, so I just sent my esc off to Tekin, and they kindly replaced it for me because I was having intermittent throttle loss. Couldn't figure it out, so I had sent it in. Well they gave me a new one(which was awesome of them because I couldn't find my receipt to prove my purchase). In the box they also had screen shots of my esc when hooked up to hotwire. They drew a big red circle over the boost/turbo screen. They said improper boost adjustments can cause intermittent power loss. However they did not say what the proper settings were, can anyone give me an idea of what "proper" boost adjustments would be?
Originally Posted by jirish617
(Post 10282605)
Originally Posted by STLNLST
(Post 10284841)
What exactly are your settings and what class do you run them in?
Are their like, presets that people use maybe? |
(Post 10285888)
I run 2wd mod buggy. I have to find the sheets, although some of the numbers were not the same as when I had last changed them which I found really strange. For example, it showed my volt cut-off and 3 something, when I had it at 6.8. My turbo delay was at 0, turbo ramp was at 2, and I think boost was in the 90's? But like I said things were changed. On the sheet it showed my delays as 2.something, and I don't recall what my specific boost setting was at...but I dont recall having it that high.
(Post 10287047)
boost doesnt go that high. If you could hook up your hotwire and take a look at your settings I can see exactly what you have and can help from there. Turbo is useless in mod buggy so there's no reason to worry about it. We'll get you in the right direction.....
What turn motor are you running? The preset profiles work pretty well in most cases. they have a 5,000 start and a 20,000 end rpm. The boost goes up slightly depending on which one you select. I'd start off mild with no more than 10-12 degrees of motor timing.
(Post 10289544)
(Post 10289910)
I'm currently running a tekin redline 10.5t with quite a bit of mechanical timing, but ill turn it down. but will soon be switching to a revtech 8.5t(i prob wont run boost then just because im sure there'll be plenty of motor for my b4
(Post 10290626)
How much is quite a bit? Each slash mark on a Redline motor is 4 degrees.
sorry if all these seems dumb, im still fairly new and learning. |
oh and here are the pictures of the screenshots tekin sent me, and by 90 i read it wrong and was going for memory. the biggest thing that makes no sense to me, is that the volt. cut off was WAY lower than i had it initially set, and i know i didn't put it at 3.35, is it possible this could have gotten messed with while it wasnt malfunctioning?
http://i5.photobucket.com/albums/y15...7/9a0754fc.jpg http://i5.photobucket.com/albums/y15...7/c9a0ba00.jpg |
| All times are GMT -7. It is currently 01:10 AM. |
