-   -   power supply (https://www.rctech.net/forum/radio-electronics/595478-power-supply.html)
darryl80 02-04-2012 09:30 PM
power supply
i am looking for a power supply that will work with a pro tek duo charger i will be buying please help me out.
darryl80 02-04-2012 09:47 PM
http://www.ebay.com/itm/12-Volt-DC-3...item2c4e8f4d27
Dave H 02-05-2012 08:09 AM
Originally Posted by darryl80 (Post 10279168)
Recommend avoiding this supply for the PT Duo. Seen a couple guys have problems with this model, it doesn't like large current surges, such as starting a charge.
Clip from the listing:
Devices/setups are recommended to have no greater than a 10 amp amperage swing/cycle (Example 5 amps to a quick/sudden 15 amp load)
The PT Duo is a fairly powerful charger, at that power level and up they like/sometimes need a little higher supply voltage, a 15V, even a 13.8V unit would be preferable. It's rated for 11 to 18V.
darryl80 02-05-2012 08:43 AM
what would be a good power supply but i dont want to spend anymore than $60.
darryl80 02-05-2012 08:49 AM
i am nw to this stuff so i need help in every aspect to work with the duo charger i am buying.
darryl80 02-05-2012 08:50 AM
how about this power supply?
http://www.ebay.com/itm/680-Watt-W-G...item3f12ccf60e
darryl80 02-05-2012 08:52 AM
dont chargers come with a wall plug to plug it into the wall? if so why do you need a power supply?
darryl80 02-05-2012 08:55 AM
or how about this power supply?
http://www.ebay.com/itm/800-W-Watt-2...item337104c735
mugenutz 02-07-2012 05:00 PM
Do you know how to rewire the ATX power supply to use with a charger?
raypa 02-07-2012 05:49 PM
I have one of the 47Amp from this site and I can use 2 Fma Powerlab charging at 20Amp each http://feathermerchantrc.com/
kcobra 02-07-2012 07:59 PM
Here is a nice article on how to convert the HP 47 amp server power supply yourself:
http://www.tjinguytech.com/my-projects/HP47A
These used power supplies go for ~$25 shipped on ebay.
