-   -   Orion R10 ESC with Hobbywing Program box (https://www.rctech.net/forum/radio-electronics/593725-orion-r10-esc-hobbywing-program-box.html)
Mb3195 01-31-2012 06:24 AM
Simple question, does the hobbywing program box work with the Orion R10 ESC? I've been told it doesn't but dont fancy forking out an extra £60 for the Orion box!!
xtaiji 01-31-2012 08:14 AM
Unfortunately it doesn't. But you can use the hobbywing program box with computer.
Mb3195 01-31-2012 08:50 AM
So if I use a laptop I can still adjust the parameters of the esc?
xtaiji 01-31-2012 09:21 AM
Yes. Our team always use like that because the orion program box is too expensive and we already have the hobbywing program box.
Kuya_Kimo 02-26-2012 11:49 PM
I've ordered the newer hobbywing xerun programming box to program my Orion R10 pro, I hope it works.
Do you use the Orion software? Can it update firmware too?
MrUnlimited 02-27-2012 02:32 AM
Yes, I think Orion esc's are made by Hobbywing like the Speedpassion esc's
FFred 02-27-2012 05:31 AM
You can update the ESC firmware and set the three different profiles, but can't update LCD box firmware, that's why it works with PC+LCD box only.
You can only use the Orion software (and Orion ESC firmwares).
If the ESC settings page doesn't show up, click on Devices then ESC (once ESC is turned ON).
Never tried with a SP LCD box, but it should work too as long as you use PC.
slater333 04-25-2012 10:45 AM
Hey guys-
I have the hobbywing programming card and am hooking it up to my R10 Pro and then hooking it into my computer. The Team Orion software does not recognize the ESC so i cannot even configure the esc through my pc (using the hobbywing programming card). any thoughts on what i should try?
defcone 04-25-2012 10:58 AM
Originally Posted by slater333 (Post 10651159)
Hey guys-
You have to use the sensor port of the esc.
Meilleur 07-27-2012 11:04 AM
Do you know where I can get the cable to connect from the sensor port to the port on the setting box?
towertsk 03-25-2015 08:44 PM
Hes any one got this to work with the latest Orion software v2.03?
Benzaah 03-25-2015 11:56 PM
Hobbywing do not make speed passion anymore. HW box and orion speedy thru the PC is the easiest way around the cost. The new Orion box does have a good battery checker as part of it but Still doesn't justify the cost.
Govert 03-26-2015 02:51 AM
There's is a typical order that needs to be followed. By heart (I will confirm this later today):
Start Orion software on your PC.
Connect program box with pc through mini usb.
Connect program box with ESC through sensor cable/sensor cable adapter.
Connect battery and power up your ESC.
If it fails, try again.
Sorry Towertsk, I did not know I wasn't answering your question, but older ones. Just try it with the new software, I'm assume it will work.
towertsk 03-26-2015 06:11 AM
Govert, please follow up after you confirm please. Can you also tell me what version of the Orion sw and hobbywing box that works. Thanks!
Govert 03-26-2015 06:24 AM
Sorry, I edited my original post, so I can confirm the procedure.
I've got version 1.71 and that works.
Download version 1.71, hook it up like I described and it must be ok.
After this, you might try the latest version (I wasn't aware of a newer version besides 1.71) and see if it works as well.
