tekin rs ----- no brakes
i need some help, i have a tekin rs and i cant get any brake. my radio is a
dx3r, motor is a novak 13.5, I Recalibrated the radio to the rs and still nothing. my epa are at 100%. this is a used setup i bought off here. i got the hot wire with it. is there a setting in the hot wire that maybe wrong and causing my problem? I have never used the hot wire or tekin products before so bare with me..
thanks in advance
thanks in advance
Did you get the radio with the ESC and then tried to reset the model?
The parameters need to be reset as well as the models.
Now if you didn't reset the radio and after recalibrating the speedo and you still have no brakes you need to use the Hotwire and check the Brake/Reverse Strength setting, Drag Brake setting, Motor type setting (for forward & brake only).
Now if all seems good and you still don't have brakes then the brake power transistors may be blown and it will have to be sent back for repair/replacement.
Go to the Tekin site and look at the Hotwire Guide section for what each function does.
