-   -   Power Capacitors (https://www.rctech.net/forum/radio-electronics/592747-power-capacitors.html)
veysel82 11-27-2012 05:11 AM
All about caps
Hi trollstomper,
Go to site : radio-electronics.com and type capacitor in the search box.
You can learn info's about caps and their usage.
Hope this helps..
vysoto 12-09-2012 09:21 PM
Single large power cap or multiple small caps ?
with would be better
running a single large capacitor like this one
http://v2.teamnovak.com/products/ind...roducts_id=444
http://v2.teamnovak.com/products/ind...roducts_id=476
or multiple small capacitors in series likes theses
http://www.nitrorcx.com/xerun-series-car-esc.html
http://www.amainhobbies.com/product_...-74V-Capacitor
any guidance would be appreciated
Ivegotklas 12-10-2012 09:29 AM
Originally Posted by vysoto (Post 11536018)
Running a bunch of small capacitors in series will actually lower the overal capacitance. Capacitors need to be wired parrallel.
series capacitance = 1/[(1/C1)+(1/C2)+.....+(1/Cn)]
parallel capacitance = C1+C2+C3+.....+Cn
As long as the overall capacitance is the same you won't notice a difference.
Edex 05-31-2013 03:53 AM
Hello from Lithuania. Help needed. My HW Xerun 150a ESC stopped working after using it in Savage Flux XL with 2200kv Mamba Monster engine and 2x 3s Turnigy 5000mah batteries. After disassembling it, 3 capasitors were bulged (Had to replace them), and one thing exploaded (Showed in the photograph). Does anybody know, is it a capasitor or a diode? postimg_.org/_image/_5hk5jcx6t/ (delete all _)
WindDrake 05-31-2013 06:33 AM
That looks like a diode. Is that adhesive residue on the transistors, or has everything cratered?
Also, that diode marked PJ1329 appears to have lifted traces all around it.
I'm thinking that board is mostly cooked.
Edex 05-31-2013 12:30 PM
Transistors are fine, so is the board. I forgot to tell you that, when I turn on the ESC, my servo works fine, there is just no sound and the LED does not blink.
Edex 06-01-2013 07:12 AM
People, help needed, I need the final answer, what is it, please help.
P.S. Sorry for double post.
