Ko propo el switch with life? >
Old 01-26-2012, 05:13 PM
Default Ko propo el switch with life?
Hve anyone tried to use the very nice ko propo e switch2 with life batteries?
I wonder how the battery meter reads when using life since it is only designed for nicad or lipo?
Cheers
Kebabkongen is offline
Old 01-26-2012, 05:57 PM
Trader Rating: 46 (98%+)
battery meter will read the same no matter what kind of battery you use. volts are volts whether it's a lipo, life,nimh,nicad, or pb.
nitroal is offline
Old 01-26-2012, 06:57 PM
Rsickles's Avatar
Trader Rating: 21 (100%+)
It will operate fine as long as you keep the LiPo mode off... otherwise it'll cut on you when your LiFe hits 6v.
The voltage meter won't be accurate either way: with LiPo mode on or off. But it will be consistent in what it does show. Best bet is just find what 5v on a dead LiFe looks like on the switch and mark it, so you know that is as far you want to drain your batt everytime you run.
Rsickles is offline
Old 01-28-2012, 05:42 AM
blade954's Avatar
Trader Rating: 23 (100%+)
while on the subject People that are using the Ko Propo electric switch how do you find them reliable or some thing to miss.....
blade954 is offline
Old 10-26-2013, 02:51 PM
yesterday I had a problem with the ko-propo switch2 and Life battery, (Li-po mode ON),,,
the servos jittering , the throttle servo is twitching with the movement of the steering servo and the opposite. When i put some load on the steering servo twitching get even worser, and steering servo would not move just shaking like it was not able to push the load, it just shaking.
It was a real puzzle, my servos were all new they're Futaba S9353HV I thought they're faulty. Day later and after 2 nights of search I found the issue (Li-Po mode should be Off) yes correct coz it was Life not lipo
MeshR is offline
Old 10-28-2013, 06:57 PM
I have used the switch with a Nanotech Life pack in my truggy for the past year and have not had a single issue with it.
lappdawg27 is offline
