-   -   Soldering BEC (https://www.rctech.net/forum/radio-electronics/591724-soldering-bec.html)
hayabusafmw 01-25-2012 11:48 PM
Soldering BEC
How can i solder the bec that comes with the GOAT3s
By the manual's standard... it says to solder it direction on the board
but it seems novak's solder is non de-solderable
i usually solder at 650F... with my hakko and it won't melt
any suggestions?
Odin544 01-26-2012 12:21 AM
Turn your iron up. Different solder has different melting points.
I usually keep mine at 800F
AreCee 01-26-2012 06:19 AM
They use lead free solder which has a higher melting point.
hayabusafmw 01-26-2012 02:12 PM
alright will try this
I heard all around that using a iron higher than 650F was pushing it too far
Guess i was wrong and so were they
NovakTwo 01-26-2012 03:06 PM
You should also be using lead-free solder to make a dependable joint. We only use/sell lead-free solder; in order to ship products to the EU, we cannot use components, or solder, containing lead.
