hyperion charger
i have a few questions about a hyperion charger. what is the minimum amps you want to look for on a charger to get a good charger? reason i ask is because i found this charger for sale it is used.
http://www.rclipos.com/HP-EOS0606i.htm any hints or tips will help me out alot. |
What size packs are you planning to charge ?
How fast do you want to charge them ? Cheers |
the size batteries i will be charging will be>>>>>2s 65c 5300mah
i hope that helps you out. |
To charge a 5300mah 2s pack requires the following charger output
1c or 1 hour (5.3 amps) = 45 watts 2c or 30 minutes (10.6 amps) = 90 watts Cheers |
would a 100-200 watt charger do all i need to do? i am new to all of this stuff.
100watt would work, but provide no extra margin for charging at higher C rates, like 3C or above, lipos permitting (newer lipos usually do). Also 200watt charger usually have a higher max charge rate than a 100watt charger. 200watt would be my choice.
I need some help guys. I'm looking for a good charger, I seen to so far the Hyperion and the venom charger what do you guys think is best of the two thanks for the help.
| All times are GMT -7. It is currently 02:14 AM. |
