-   -   80A Xerun Help (https://www.rctech.net/forum/radio-electronics/588428-80a-xerun-help.html)
onceaday 01-16-2012 07:57 PM
80A Xerun Help
I just popped in the 80a Xerun and did the ESC setup with it and did not change a thing on the ESC. i also put the radio settings back to where it said to in the directions but something happened. The car took off like a rocket as soon as the lights kicked off and out of programming mode. I have some nice damage done to some furniture, almost woke up the kids, and have a nice burned rubber mark on my calf from a 2s 50c coupled with a 4.5turn brushless motor turning the tires so fast.:cry: i was swinging the stupid thing around trying shut it off before the tires exploded...completely ballooned out. anyway, has anybody had this happen before? my throttle is still centered and my endpoints are at the 100% like it wants...i just have no clue as to why it would try to take off like that. never have anything like that happen before on my other escs....any help would be appreciated. if it makes a difference i am running an m11, spektrum module, and the 3001 pro rx. the same setup works fine on the other cars...
hotrod87 01-16-2012 08:34 PM
Try unplugging the motor and reprogram the esc.
burnineyes 01-16-2012 10:11 PM
LOL it sounds like you mixed up the neutral and full throttle endpoints during programming. I agree to unhook the motor and reprogram it. Before connecting the motor check the LEDs, should be OFF at neutral.
