-   -   charger newbie..! (https://www.rctech.net/forum/radio-electronics/587804-charger-newbie.html)
60_cent 01-15-2012 12:26 PM
charger newbie..!
I'm not clear on a few this with my new charger. I just purschased a Sky RC IMAX Quattro B6. So far I only have NIMH batteries to charger. I have several 9.6v packs for my transmitter and 6.0v hump packs for my reciever on the car.
When charging how much current/amps should I set the charger to. My charger can go from .1 to 6..
Also is it a good idea to use the charger to charge my 12v battery in my bump box? If so what setting should I use for that??
60_cent 01-16-2012 11:05 AM
anyone?
Also I plan to getting together a 2wd sct to run this spring. How long would my charger take to charge a 2s lipo?
The charger is 50w x 4.
modelfan 01-16-2012 11:33 AM
You'd be safe with a .9-1.0 amp charge rate.
You can use your charger to charge your starter box battery but it will take too long. I would recommend you get an overnight wall charger from an automotive store for this. They're inexpensive and work fine. Also down the road you may want to consider a lipo pack for your starter box and your charger will charge it faster. I went that route last year and never looked back. Also a hell of a lot lighter!
There are other factors to consider (motor type, esc, how hard and long you run) but generally your 2s lipo should take about 30-40 mins to charge at 1C.
60_cent 01-16-2012 01:54 PM
THANKS!!
