Servo question, please set my mind at ease..
Just picked up a Futaba S9350 servo for a Losi XXX-SCT I'm putting together. I see it mentioned as a 1/8 scale servo and high-draw, etc... Is this going to cause me any problems? I plan to run a basic brushless system (Castle SCT maybe) with 3300 NIMH packs for now.
Here are the servo specs for reference. Doesn't seem to have any extraordinary torque/speed... Thanks in advance for any feedback! Control System: +Pulse Width Control 1520usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave Operating Voltage: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.15sec/60 degrees at no load Operating Speed (6.0V): 0.12sec/60 degrees at no load Stall Torque (4.8V): 111 oz/in. (8kg.cm) Stall Torque (6.0V): 139 oz/in. (10kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: Yes Direction: Counter Clockwise/Pulse Traveling 1520-1900usec Motor Type: Coreless Motor Potentiometer Drive: Indirect Drive Bearing Type: Dual Ball Bearings Gear Type: All Metal Gears Connector Wire Length: 12" Dimensions: 1.6" x 0.8"x 1.5" (41 x 20 x 38mm) Weight: 1.4oz. (41g) |
I run a very similar setup with that same esc/motor combo you mentioned and it worked ok for the most part but I'd periodically get random glitches while driving.
Sometimes on tighter portions of the track I race at I'd lose steering briefly, or on a high-speed sweeper where I was at almost full-throttle while holding a long turn. A couple times the glitches almost caused a very serious crash! I since added a capacitor to the system and I've yet to experience any of the glitching. I'd highly recommend that for sure. Cheap insurance! |
| All times are GMT -7. It is currently 04:49 AM. |
