-   -   flysky ABS help ? (https://www.rctech.net/forum/radio-electronics/580216-flysky-abs-help.html)
sonnier00 12-22-2011 06:02 PM
flysky ABS help ?
Can someone out there help understand how to set the ABS system up? I need help Range, Cycl, duty, level, stm what is happening and where to start.
TIZAO 12-22-2011 07:08 PM
With out ABS when you jam on the brakes it will lock up your wheels..... when you have ABS on it will release the brakes for a quick mili second and then reapply them again... doing this repeatedly until you no longer ask for breaks with your trigger..... slowing the abs will cause more time in between the breaks reengaging and speeding up the abs will cause less time inbtwn the brake engagement.... I hope this helps! And I hope you understand....
sonnier00 12-22-2011 07:52 PM
that helps a lot. Now I need to figure out the numbers to set it at Flysky talks about scope 0-100. If they use the same rule through out there manual then 0 is fast and 100 is slow for cycl & duty, (range: output range when brake) 0 is hard 100 is soft.
Did I get it?
highster 12-23-2011 06:07 AM
Good question I was wonder this same thing, as i cant notice much difference between using ABS and not using it.
