-   -   saddle question (https://www.rctech.net/forum/radio-electronics/580029-saddle-question.html)
gogi108 12-22-2011 02:47 AM
saddle question
hi , im running 1/10 buggy with saddle packs , im finding space to be an issue with the balance plug , deans ect in the wiring . i want run bullets straight from esc to to packs , and of course series wire , leaving out the balance gear . i will keep the current gear with balance wire purely for charging . what i'm asking is - is it ok to discharge without balance wire ?
cheers gopes
ufoDziner 12-22-2011 03:54 AM
If you mean running your car without the balance tap in place, it is perfectly okay. If you're running an actual discharge sequence through your battery charger/discharger, then you need to have the balance tap in place and connected.
cheers gopes
gogi108 12-22-2011 05:46 AM
thanks mate , it was a pretty hard question to word , yep discharge on the track . cheers
