Castle sv2 problem
ok so i got a xxx4 today it has a sv2 esc and a 7700 kv motor. Plugged my reciever in and nothing. The servo moves the green light comes on but no power. Battery is charged reciever and radio are good. At one point it did work for about two mins and now nothing again. Anyone have any ideas i could really use some help. This is my first brushless system so i have no idea what to do.
thanks travis |
Did you buy this setup used? If so did you calibrate the esc to your radio? This is a must if you haven't. Also what radio rx and batts are you using?
The setup was slightly used so no I didn't calibrate it. I have no idea how to do that. And I'm using an m11 with spektrum an I have Orion 3000 mah nihm batteries. Pleaser explain how to calibrate it.
Thanks Travis |
Castle Drivers Ed ESC setup guide, good reading
http://www.castlecreations.com/suppo...s_ed_guide.pdf Cheers |
| All times are GMT -7. It is currently 04:05 AM. |
