-   -   need help (https://www.rctech.net/forum/radio-electronics/578481-need-help.html)
kbmgasaints 12-16-2011 05:40 PM
need help
im having a problem with my transponder not counting all the time
what is happening is when i run my digital servos the light on my transponder
will flicker and so its not counting all the time and i dont know why..
i have a brand new mamba max pro and my receiver is a specktum pro
i can firgure out what going on any ideas will be helpful thanks
the transponder is a amb transponder
crusey_aus 12-16-2011 05:50 PM
You may be loading up the ESC's internal bec
Try a glitch buster style capacitor or external bec
Cheers
kbmgasaints 12-16-2011 06:55 PM
thanks for input
kbmgasaints 12-23-2011 07:29 AM
well the glitch buster didnt work so i will try the external bec
adrictan 12-23-2011 07:32 AM
If u have a spare port on yr receiver, try plugging it to tht port and see. Alternatively, shift the posn of the transponder.
jwmustang 12-23-2011 07:38 AM
If it is flickering its 95% a power problem. Either BEC is bad, too weak (glitch buster) bad connection somewhere. Does it happen only when you are turning?
kbmgasaints 12-23-2011 08:02 AM
yep only when im turning with or without the front wheels on the ground
