project recharge...
2 Attachment(s)
i was board and had a brand new life pack laying around, and installed in about 15 min, and this pack has dual power leads, one jst plug witch i sniped off and soldered and a standard rx battery type plug witch i will use for charging and the balance leads are free.
Nice, LiFe/LiPo is definitely the way to go for radios.
What benefit does that provide you that a set of Sanyo Eneloop LSD nimh cells cant ?
Cheers |
Originally Posted by crusey_aus
(Post 10035961)
Cheers Additionally, it is lighter than 8 NiMH cells. |
Looks like a 2 cell pack to me
1100mah @ 6.6v vs a set of 4 x 2000mah Eneloops @ 4.8v Cheers |
(Post 10035975)
1100mah @ 6.6v vs a set of 4 x 2000mah Eneloops @ 4.8v Cheers Forgot the newer Spektrum stuff runs 4 cells. |
(Post 10035975)
Not sure its any cheaper
Latest Eneloops are good for 1500 charge cycles, how many is your pack good for ? Pretty sure 1100 mah @ 6.6v would provide pretty much the same uptime as 2000mah @ 4.8v Cheers |
| All times are GMT -7. It is currently 03:18 AM. |
