-   -   whose 4mm bullet connector is the best (https://www.rctech.net/forum/radio-electronics/570831-whose-4mm-bullet-connector-best.html)
asc6000 11-22-2011 01:17 PM
I see prices from 50 cents to 3 dollars for a single bullet.
This is not an area to skimp but no sense in getting the $3 ones if the $1 works just as well if not better. More money for tires :)
Currently running deans but slowly switching to bullets for cleaner wiring and hopefully better current flow.
racer1812 11-22-2011 09:56 PM
Castle are some of the best, at least the style is. Duratrax also makes the same style. Either way pass on the "basket" or "cage" style.
good...
http://www3.towerhobbies.com/cgi-bin...?&I=LXTJH8&P=7
these also work well, IMO.http://www3.towerhobbies.com/cgi-bin...?&I=LXYXF3&P=7
anything but these!!!
http://www3.towerhobbies.com/cgi-bin...?&I=LXJPY4&P=7
all IMO of course
racer1812 11-22-2011 09:59 PM
I wouldn't do it for more/better current flow. No real gain IMO unless it's in maybe an E8 car. Does make for a nicer/cleaner set-up though. Just don't plug them in backwards..:deathstar
AreCee 11-23-2011 05:15 AM
A-Main's Pro-Tech plugs are rather nice. Good tight fit and they have a cutout so you can lay the wire down.
Walkman 11-26-2011 06:07 PM
I like the Duratrax the best.
joe c 11-26-2011 07:05 PM
+1 for the castle plugs.
:nod:
they have bigger too, but I like the 4mm ones linked in post #2.
lodhammerdin 11-27-2011 10:37 AM
I use these:
https://www.ssl-stormerhobbies.com/c...=ns&pn=ASC0663
Never had any problems with them. I know the link is to 3.5 mm bullets, but reedy makes 4 mm bullets.
lodhammerdin 11-27-2011 10:51 AM
heres another link.
http://www.teamassociated.com/reedy/parts/details/654/
junkman12 11-27-2011 09:56 PM
I don't think you can beat the castle's. The 4 prong style is def the way to go over the rugular banana ones or whatever. I gave the hobbyking 4 prong ones a try, but they are much weaker than the castle ones, you have to spread them with a knife about everytime you unplug them to keep them tight.
cherokee95 11-27-2011 11:16 PM
I like the Duratrax ones myself. Nice low profile clean look, they fit nice and tight. Good rule is to route your wires so you can't plug them in backwards.
