Mamba Max Pro LVC Question..
Hello.
I was interested in changing the setting on my MMP ESC for the Low Voltage Cutoff from the default setting of (auto-lipo) which is 3v per cell to more like 3.3v-3.5v per cell. But, i can only see an option to change it to the next size up battery to simulate a higher voltage cutoff. Would this work? If i was using a 3s battery and set it to think it was on 4s that would simulate the LVC to be at 4v per cell. Is that a little high though? Will i be ok if i leave it on the autolipo mode? I dont want to damage my packs. Thanks. |
Now i think i just got myself confused.
I was told that i should have my LVC set up a little more than 3v per cell. More like 3.3-3.5. How can i achive this? |
I don't have the Castle Link software in front of me but what you are trying to do will work. If I remember right you leave the cell count detection at auto. Then set the per cell cutoff to custom. Then you can set the value to whatever you want. I run my cutoff at 3.4v per cell.
Thanks.
Im gonna order up the castle field link to tune it to 3.2v per cell. Think ill be alright for a couple of days running it on auto lipo? Its in a sc8e with a 2200kv on 3s only. If i run it hard until i hit the LVC the voltage will come back up wont it? Maybe ill just stop running it early until the field programmer gets here. |
If you are using auto-lipo mode then the LVC is adjustable between 3.0 - 3.5v per cell
If not using auto-lipo mode then you can set total pack voltage to any value you like Cheers |
Originally Posted by crusey_aus
(Post 9832263)
Originally Posted by die-laughing
(Post 9832259)
Thanks.
| All times are GMT -7. It is currently 10:59 AM. |
