Need some help clarifying what controls the voltaged to a servo
I see some Servos offer two different input voltage and it changes the speed/TQ of the output.
I did a search on here about it and I wanted to make sure I understood it The ESC controsl the power to the servo at x voltage. That x voltage is the controlling factor on what voltage the servo see's to pick the output 4.8v/6.0v So the internal BEC ( if equipped) or a external BEC controls the voltage to the Servo ? Sorry I am kind of new to the game on electronics on the cars |
Your ESC's internal bec supplies the reciever and therefore the servo in a normal setup
Where the requirements (amp draw) of the servo are too big, people install an external bec External bec's can supply a higher stable voltage and higher amp draw than most ESC's Cheers |
Originally Posted by crusey_aus
(Post 9791057)
Where the requirements (amp draw) of the servo are too big, people install an external bec External bec's can supply a stable voltage and higher amp draw that most ESC's Cheers awesome, thank you |
| All times are GMT -7. It is currently 05:48 AM. |
