-   -   JACKED UP STEERING!! HELP!!!!! (https://www.rctech.net/forum/radio-electronics/557818-jacked-up-steering-help.html)
TXMulisha 10-08-2011 06:58 PM
I have a AE SC10. Spektrum DX2 transmitter, Spektrum SR3000 reciever and a AE SHV 1504 servo, with a Sidewinder SV2 speed control, Castle 1406-1Y 5700 KV brushless motor. My problem is this, I run it and I am getting a seriuos steering problem. Sometimes it will hit a bump and turn to the stop either right or left and stay there. Other times as I pass myself ( from one side of the transmitter to the other) the steering will reverse? As you can imagine this make the truck imp:flaming:osible to drive! Help would be appreciated!!:cry: Oh and I am running a Winforce 30C 5000 mAh LI-PO battery.
crusey_aus 10-08-2011 07:13 PM
Sounds like a bec related issue, common with Castle ESC's and higher powered servos
You may need to install a glitch buster style capacitor or better still an external bec
Cheers
TXMulisha 10-08-2011 07:16 PM
BEC?
just getting back into RC so not real familiar with new tech and terminology. What is it and where do I get it?
crusey_aus 10-08-2011 07:27 PM
This will get you started
http://www.castlecreations.com/suppo...user_guide.pdf
Cheers
TXMulisha 10-08-2011 07:44 PM
Thank you for the info! I am really excited to be back in the hobby but the technology has changed a bit in 10 years!
