-   -   Help!! SR3000rx won't bind (https://www.rctech.net/forum/radio-electronics/553785-help-sr3000rx-wont-bind.html)
adriang79 09-24-2011 06:07 PM
Hi all,
Hoping someone here might be able to help me out.
I bought a second SR3000 rx for my Spektrum DX3.0 so I could run my newly purchased touring car in addition to my mini. When I attempt to bind this rx the LED will flsh showing its in bind mode, but it doesn't stop flashing when I complete the binding process.
Is this rx no good? Or is there something else I should be doing??
Any help will be much appreciated
Adrian.
racer1812 09-24-2011 10:25 PM
I've had it take several attempts, are the radio batteries fresh? I've had this be an issue in the past...
adriang79 09-25-2011 01:19 AM
I've probably tried about 15 times now. Batteries should be pretty fresh, might top one up and give it another go.
adriang79 05-11-2012 07:50 PM
Finally sorted it. Pulled it apart and sprayed it out with WD40, then dried it with compressed air.
Got it to bind first go and works great!!
