-   -   Please help Leoperd esc on slash (https://www.rctech.net/forum/radio-electronics/545650-please-help-leoperd-esc-slash.html)
dalolyn 08-27-2011 03:06 PM
I cannot get the 70A leoperd esc to calibrate
instructions say to switch on transmitter. switch on the esc while holding the set button. release, idle, press set, light flashes once green, pull to full forward, press set, light flashes twice, push to reverse, press set, light flashes three times. then motor goes to full forwards.
Anyone know how to calibrate for a stock slash.
poppa_duce 08-27-2011 06:20 PM
You may need to reverse the throttle servo.
dalolyn 08-28-2011 09:45 AM
WOW talk about failing eye site. I realized the traxxas receiver has 2-ch.1s and 2-ch.2s. So I had the wire from the esc plugged into ch.1 No wonder the esc responded when I turned the steering. Works great now.
