-   -   tekin rx8 help (https://www.rctech.net/forum/radio-electronics/541394-tekin-rx8-help.html)
gnatsum69 08-13-2011 01:00 AM
tekin rx8 help
i have a tekin rx8 setup in an losi xxl running 4s with 2000kv motor dx3s controller and tele. i did strap the battery in properly as i was only showing someone the truck. got a little carried away and went fast etc battery strap came loose battery fell out on the dirt running deans connecters it would of given the connector and wires a bit of pull but no wires are broken but now i have nothing working at all no steering or anything. it still makes a little arc when i connect the battery but nothing else. i have powered up the rest of the system with out the esc connected using a rx pack the controller rx etc are fine. any ideas???
chucko 08-14-2011 01:31 PM
go to the RX8 1/8th scale official posting for tekin and Randy Pike can help you with that. or call Tekin service. its in the elect off road section
BigRM 08-14-2011 02:11 PM
Sounds like the switch is either shot or one of the wires running from the switch is damaged or disconnected from the board.
