losi t ten starts itself
have a t ten when you turn on receiver it tries to start itself is it a short or do I need to rebind put new battery and servos in
rebind wouldn't hurt. is this the first time ?
have you run it before? maybe your radio throttle end point got moved ..there is trim adjustments that will help that. What radio and what speed control ?
Check the starter button on the radio and make sure it's not sticking. If it's not, check all of the wires, make sure there not bent, broken, etc.
