-   -   FlySky GT3b Hack Tech Thread (https://www.rctech.net/forum/radio-electronics/538922-flysky-gt3b-hack-tech-thread.html)
-Goat- 02-05-2013 02:22 PM
Originally Posted by Spooke (Post 11698073)
I believe you can download it from the Radio by going to Read, Current Tab, and then saving the file, however this didn't work for me, I have someone elses original firmware though, here you go.\
I am also having issues with the custom firmware, I have the GT3B-0.61 firmware, I am trying to get the steering to both have the 150% end point, however I can only select the end point for steering right. It's in channel 1 and esc is in channel 2.
Can anyone help me!! Thanks!
I'm not 100% sure as I'm not at home, but I think you have to rotate the steering wheel right or left to display an arrow for the direction you want to adjust.
-Goat-
-Goat- 02-05-2013 02:29 PM
Here is a link to a post that has a very user friendly manual for the GT3B/C hacks.
http://www.rctech.net/forum/radio-el...re-manual.html
-Goat-
NOLAG05 02-07-2013 09:10 AM
So for your guys/gals that have this radio...
1. How is it with out the mods for regular racing?
2. For those modded how is now for racing?
I am on the fence for this radio but do i need it modded for regular use?
Thanx!
Jfin66 03-01-2013 08:35 PM
Just flashed to 0.6.1 and now the I have some glitching on channel one (steering). Once in a while the steering servo will move then return to center when there is no steering input (even set the radio down and it happened while the radio was sitting on a table). Never had glitching issues with stock firmware.
Trouble shooting steps taken:
Rebound the Rx and TX
Changed the number of channels from 3 to 2
Recalibrated the Tx
New Battries
Changed Servo
Added/Removed Glitch Buster
Changed to 0.5.0_3Channel and no glitching after an hour with the TX sitting on a table
Would appericate any trouble shooting tips.
MadRacer 03-03-2013 03:43 AM
Li Po Alarm ????
Hi.
Need some advice please. I bought a hacked 3GTB of e bay. Not sure who did it but did say it wasn't worth doing anymore as it took too much time for the money he gets back.
While I have all the mods that i wanted like 72 model memory. One thing that I can't do is find a source to plug in my li po alarm. The switch is the obvious place to tap in but I can't access the wires that go into the switch.
Other wires i checked with a volt meter arent 12v so I cant tap into them.
Very frustrating as I just lost another li po battery from leaving it on. My fault but if the buzzer was connected this would have saved my li po.
Any advice would be much appreciated. I did ask on the 3GTB thread with no response!!!!
Fast1Guy 03-03-2013 06:16 AM
On a GT3B with firmware 0.6.1 you can set the low voltage alarm and the inactivity alarms to what ever you like in the global menu. No need for a buzzer. Global menu also tells you your firmware version.
MartenDavis 04-09-2013 02:42 PM
Firmware 3B vs 3C
Is the firmware the same for the 3B and the 3C? I am having trouble generating a custom firmware using my stock firmware.
Thanks,
Marten Davis
danjr1 05-19-2013 09:00 AM
hey,
Am just wondering if anyone could clarify how the hacked GT3b failsafes? Can it be programmed or does the receiver just stop outputting signals?
Cheers
Dan
Fast1Guy 05-19-2013 09:30 AM
Originally Posted by danjr1 (Post 12167755)
hey,
Cheers
Dan
You set it at the receiver for the throttle channel. Doesn't matter if the radio is hacked or not. Works well.
danjr1 05-19-2013 09:58 AM
Is this the only channel it will failsafe on? Im thinking of using the system to control a fighting robot but the rules require everything to failsafe i.e. weapons such as spinning blades etc.
Cheers
Dan
lrhsrzed 06-29-2013 07:03 PM
programing
is there any way to get just a backlight, low voltage setting, inactivity alarm, and a latency, and a 3rd dig or 4wheel steer program??? i don't think i need all the rest, i'm not very good at programing this
tjmoes 07-11-2013 10:45 PM
how u set it back to factory defaults after doing everything wrong
theblitzkidd 07-12-2013 10:34 AM
Hi all ya hack phreeks heehee I was jw if it is in anyway possible to make another receiver (other than the flysky ones) to bind to the radio, in particular, I have a bunch of the associated xp receivers! Thanks:)
lrhsrzed 08-12-2013 07:48 PM
well since no response i just bought another gt3b did regulator and bearing mod but i wont hack it can't figure out how to get end points and some other things to work properly :flaming:
CerberusVI 08-23-2013 04:39 PM
So im trying to put together an order on Digi-key or mouser for the parts to do the hack mod's and im having a hard time finding the correct pin header to install on the radio.
Im looking for a right angle 4 pin molex header with 1mm pitch correct? i keep coming up with 2.54mm pitch stuff
