Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-08-2011, 07:19 PM   #1
quik418's Avatar
Default I need a charger!
I need a decent AC-DC charger capable of charging two batteries if I needed with out spending a fortune. I'm thinking about buying a Venom Pro Charger Plus or something similar. Any recommendations?
quik418 is offline   Reply With Quote
Old 07-08-2011, 08:12 PM   #2
Charger: http://www3.towerhobbies.com/cgi-bin...&I=LXAYVD&P=ML
Power Supply: http://sites.google.com/site/tjinguy...projects/HP47A
kcobra is offline   Reply With Quote
Old 07-09-2011, 10:12 AM   #3
Trader Rating: 21 (100%+)
There are no worthwhile AC/DC powered dual chargers that I'm aware of. The Hitec or its re-badged cousin ProTek charger are good options -
http://www.amainhobbies.com/product_...S-10A-200W-x-2
You'll need a 20amp PS as a minimum.
Duster_360 is offline   Reply With Quote
Old 07-09-2011, 10:35 AM   #4
Trader Rating: 32 (100%+)
Hobbico Elite is a dual ac/dc unit . But you didn't mention the batteries you'd be charging and your specs preferences .
gulio is offline   Reply With Quote
Old 07-09-2011, 11:34 PM   #5
Yosh70's Avatar
Trader Rating: 17 (100%+)
Why dont you actually look at the charger instead of recommending something like that?
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 07-10-2011, 09:47 AM   #6
Its only 2amp max in each port and 3S lipo max. Looks like its intended for small batt charging for planes.
This is a quote from the manual on pg 2 and explains everything -
"Designed for Tx and Rx radio batteries. Also good for single cell glow igniters and even lithium-based park flyer batteries!"
Old 07-10-2011, 10:20 AM   #7
Unfortunately the only thing we have to go by is what OP posted. I will admit that I didn't reasearch quik's packs , but nonetheless the Elite does fit the bill given the info here.
ps. I DO look at this charger from time to time and recommend it. It would be a poor choice if it was not within specs. It will also have a hard time doing 2 amps on 3S packs , it is only around 36 watts or so with the stock ps.
I need a charger. Which one is good for beginners? Can I do it under $50? dan50 Radio and Electronics 12 09-24-2009 09:44 AM
DUDE MY CHARGER FRIED, I NEED A CHARGER!!!! Sushi Man R/C Items: Wanted to Buy 19 12-02-2005 02:07 PM
ok, I need a charger/discharger/cycler, etc. Aparatchik R/C Items: Wanted to Buy 6 11-15-2005 10:58 PM
I need a charger! Suggestions? d2create Electric On-Road 9 12-28-2002 10:50 PM
