Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-06-2011, 05:28 PM   #1
smittyusmc's Avatar
Default Battery wont charge
Ok so I have a Venom Pro Charger and a Protek LiPo 11.1v 3 cell 2300mah and every time I pull it in and try to charge it it keeps saying that the connection break but I have tryed to different plugs and it keeps doing it. My other Lipo which is a protek 7.4 5600mah chargers just fine. I 11.1v has only been charged one time and that was the first time I used it. It goes in my radio it reads 11.2v on my radio. Please help. Thanks
Radio Is a 3pk
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 07-06-2011, 06:54 PM   #2
One of my batteries does this from time to time. I just wiggle the balance lead and it works after that. Mine appears to have a loose balance wire internally.
mellen_mpz is offline   Reply With Quote
Old 07-06-2011, 08:16 PM   #3
Trader Rating: 21 (100%+)
The older version of this TX lipo came with no balance wires - I have one like that. Try charging without the balance wires connected at a low rate like 1amp.
They were higher capacity too, think mine are 3000mah.
That's what I do with the one I have w/o balance wiring. You might have a connection prob internally with one of the balance wires. Only way to find out is to open it up and start trouble shooting the wiring with a DVM. Or charge it without...
Duster_360 is offline   Reply With Quote
Old 07-07-2011, 11:30 AM   #4
Paul Susbauer's Avatar
On the Venom Pro-Charger, if you have a Connection Break, then that is indication there is a problem with the main power leads, not the balance leads.
If the balance lead is not hooked up (or a connection problem) the error would be "Battery Vol Error - Cell Connect"
Paul Susbauer
Venom Group International
Paul Susbauer is offline   Reply With Quote
Old 07-08-2011, 12:36 AM   #5
smittyusmc's Avatar
Ok so I pluged up my battery without the balancer and it charged just fine the balancer was still pluged into the charger just not into the battery. But doesnt the battery need to be balanced should I buy a balancer. thanks
Old 07-08-2011, 07:45 AM   #6
Venom says you have a prob with the main power wires. I'd look them over carefully. If this lipo is new, sometimes the connections need to be re-soldered. I wouldn't buy a separate balancer for just this lipo.
New niMH packs that wont charge, help!! UltegraSTI Electric On-Road 14 09-25-2017 03:59 AM
Lipo wont charge JimmyS1985 Electric Off-Road 8 06-09-2011 07:08 PM
lipo wont charge microbomb Electric Off-Road 6 06-10-2010 03:12 PM
New Turnigy Lipo wont charge fievel Electric Off-Road 9 05-08-2010 01:32 PM
