Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-06-2011, 03:24 PM   #1
Default how to care for a nickel metal battery
i just got a brand new nickel metal battery pack for my cup racer havent done anything with it yet do i charge it first or run it completly dead then charge it ? i have a good charger just want to know what is the best way to get the most out of this pack considering i spent a good chunk of change on it
current line up
traxxas tmaxx pro .15
traxxas tmaxx pro .15 converted to 2,5
traxxas jato
hpi cup racer 13.5 turn brushless
bonvo is offline   Reply With Quote
Old 07-06-2011, 08:20 PM   #2
Trader Rating: 21 (100%+)
Depends on what the cell manufacturer or pack assembler recommends. This is what ProMatch recommends for their cells - charge first at low rate and watch temps!
http://www.promatchracing.com/stickpackins.php
If you spent that kind of money, ask them - do they need breakin and if so what do they recommend. They should be glad to help out with advise.
Duster_360 is offline   Reply With Quote
Old 07-06-2011, 11:08 PM   #3
the pack came with no instructions so im at a loss i think ill charge it with a slow charger then go from there
current line up
traxxas jato
Old 07-07-2011, 06:36 AM   #4
Dan-RC's Avatar
I think that you should charge it first. Ni-MH batteries still shouldn't be drained fully to where the truck isn't moving anymore. How many mAHs is it rated for? That will tell you how many amps you charge it at.
4000 mAH = 4 Amps, 1 Hour Charge Time
5000 mAH = 5 Amps, 1 Hour Charge Time
Dan
Dan-RC is offline   Reply With Quote
Old 07-07-2011, 11:19 AM   #5
Paul Susbauer's Avatar
I usually charge the NiMh Packs when new at 1C (C being capacity)
So a 3300mah pack, would be charged at 3.3 amps. Watch the temps. Should be 120 degrees F or less. (Should be able to hold in your hand without discomfort)
Discharge: I discharge to .9 volts per cell. (5.4 volts in the case of a 6-cell pack) For the first few cycles, again, discharge at 1C. So 3.3amps.
When storing for a long periods of time, be sure to check to make sure the pack voltage doesn't drop to 0 as your pack may be damaged. Usually if this happens, the pack will charge up, but then will not have any punch, or will not hold the charge if left for a day or two.
--Paul Susbauer
Venom Group International
Paul Susbauer is offline   Reply With Quote
How to solder correctly (a not so brief lesson) marine6680 Radio and Electronics 551 11-09-2017 10:52 AM
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
