-   -   Need advice on a charger. (https://www.rctech.net/forum/radio-electronics/527773-need-advice-charger.html)
stevo9 06-28-2011 07:13 AM
I'm new to the hobby. I am almost done building my FT TC5. Motor, esc, & rx/tx get delivered tomorrow. I need advice on a charger. I want something that is ac/dc, charges all types of cells, built in balancer and peferably charges a couple at a time. What do you recommend that isn't super expensive?
Duster_360 06-28-2011 10:42 AM
Thunder AC6 from Hobbypartz -
http://www.hobbypartz.com/thac6smbachw.html
Axoman 06-28-2011 11:43 AM
What about the AC680 Professional?
Is it worth the extra $15?
Duster_360 06-29-2011 12:57 PM
Only if you need the extra power - 680 is an 80watt charger with a max charge rate of 6amps, AC6 is a 50watt charger with a max charge rate of 5amps. If you're only charging 2S lipos, AC6 is plenty unless your 2S lipos are greater than 5000mah capacity.
680 is a bargain though for the money getting that added power and increased charge rate.
stevo9 07-01-2011 05:48 PM
Is this pretty easy to use? What do you think of the hitec one that does 4 batts at once?
kcobra 07-01-2011 06:42 PM
If you think you are going to stay in RC for a while you should really think about getting a DC only charger. When limiting yourself to AC/DC chargers you pay a premium for the sub-par AC capability compared to an external power supply. If you are looking for a dual channel charger that is relatively cheap, I recommend the Hitec Ultima X2:
http://www3.towerhobbies.com/cgi-bin...&I=LXAYVD&P=ML
With Tower coupon you can get it down to around $125.
For the power supply, see the following page on how you can use a high powered server one for around $25:
http://sites.google.com/site/tjinguy...projects/HP47A
Duster_360 07-02-2011 11:45 AM
Its easy to use once you understand the menu system these use.
If you're considering a multi battery type charger, you will be looking at a DC powered charger. The Hitec one you mention is DC powered and requires a separate power supply. Its limited to 50watts per port and 5 or 6amps max charge rate. Unless you really need to do 4 at once, the Hitec X2 is a better charger with more power and more flexibility.
http://www.hitecrcd.com/products/cha...ipment/x2.html
