3 min run time. Please help
Hi guys I have a sc10 4wd and a rx 8 tekin and 4xsc 4.5 motor 4800kv my battery is a sky lipo 2s 5000 40 c why am I having only 3 min run time my gear ratio is 14 pin and 62 spur 32 pitch can anyone help me with this I also just ordered a thunder g6 5300 mah 60c pro race do you think this will help thanks jay
Hey Jay,
A few things to start with would be how are you charging your batteries, and what your lipo cutoff is set to. Also, I would check motor/ESC temp as soon as it stops to make sure it is not going into thermal shutdown. This should not happen at 3 min, but I have seen crazier things happen. |
Rx8 cutoff
The rx8 has a 6v cutoff for a 2s so I don't know if I can change that I have a thunder dual power ac680 charger my capacity cut off is 5000 mah on charger u can turn that off input power is set low cut off is 10.0 v it's set to v type 3.7v lipo check time is 5 min whatever that means also USB /temp cutoff is 80c waste time is set to chg/dchg to 10 min
Maybe this can help you to help me. I'm lost. Thanks again for your help |
So are you charging the lipos to the 4.2v per cell 8.4v total on your 2s lipo?
Reply charge and run time
Its a 7.4 v 5000 mah 2s lipo so rite now I'm set to 2.0a it's at 7.32v each cell is balanced at 3.66v. Thanks again guys
Originally Posted by jason55
(Post 9288455)
Trust me charge them to the 4.2 per cell and you will be flying for 25+min easy. Look at the charging section in this link below http://en.wikipedia.org/wiki/Lithium...olymer_battery I personally set my cutoff on the esc at 3.2v per cell and charge to the 4.2v per cell..... If your not going to use the packs for awhile put them in storage mode by charging them to 3.8v per cell Also are you charging at 2amps? If so you can bump it up to at least 5amps with that pack. |
Yeah the 7.4V is just a nominal voltage, a 2s 7.4V pack should be fully charged at 8.4V. I do not have the RX8 but it should have an adjustable cutoff voltage, typically you dont want to run them down to 6V every time as it will shorten the life of the pack.
Thanks for helps guys
Well at 7.4 v I was getting 3 min so now once I'm at 8.4v we will see what i will get I'm gonna go out and check it out guys thanks again 7.88v getting there
Lets us know how it works out....:)
I love Rc tech could not do it without ya
Thanks so much im new to this I know I have a good setup and put alot of time and money into this setup and knowing I have people that know what they r talking about is awesome thanks again jay
Jay, you might want to read up on lipo so you understand a little about them -
http://www.rchelicopterfun.com/rc-lipo-batteries.html Once you start with a fully charged one, run time will be much improved. |
| All times are GMT -7. It is currently 08:27 AM. |
