-   -   converted ATX power supply help (https://www.rctech.net/forum/radio-electronics/522170-converted-atx-power-supply-help.html)
cm367700 06-10-2011 04:40 PM
I just converted my power supply and everything was working fine and had a output of 12v. when I plugged in my charger (the polarity was correct) the power supply went dead. anyone know whats going on?
whitrzac 06-10-2011 05:10 PM
you need to have the charger plugged in when you turn it on
cm367700 06-10-2011 05:24 PM
it was. the fans only spun for a second and stopped. but i know power is going through it cause I got shocked....
whitrzac 06-10-2011 06:29 PM
if its shocking you, you have other issues...
somthing is wired wrong, or it is a bad psu
cm367700 06-10-2011 06:49 PM
no. its neither of those cause I've checked the wiring and I tested the PS before I bought it.
nitro_mt_racer 06-10-2011 07:38 PM
Like stated previously, it shouldn't be shocking you. Got any pics of this converted power supply? Is it possible that your positive post is touching the grounded case and causing a short?
cm367700 06-10-2011 07:49 PM
ok so I found a blown capacitor.....
http://i868.photobucket.com/albums/a...8/DSC03809.jpg
heres the conversion. I took it off the board to look around.
http://i868.photobucket.com/albums/a...8/DSC03810.jpg
nitro_mt_racer 06-10-2011 07:56 PM
The blown cap is the result of another problem. Still guessing that you've got a short somewhere. Is the positive post isolated from the case?
cm367700 06-10-2011 08:08 PM
ya. the posts are fully insulated with nylon. I have a resistor on there but idk if i wired it right or not. but impretty sure that they dont have a certain polarity
http://www.radioshack.com/product/in...ductId=2062290
nitro_mt_racer 06-10-2011 08:13 PM
Do you remember what you were touching when it shocked you? Can you take a pic of the ps from overhead? I don't see anything in the provided pics that's obvious anyway.
cm367700 06-10-2011 08:19 PM
Well I remember that I was reaching between the heatsinks and and I guess I touched the purple wire that was exposed.
http://i868.photobucket.com/albums/a...8/DSC03812.jpg
http://i868.photobucket.com/albums/a...8/DSC03811.jpg
nitro_mt_racer 06-10-2011 08:39 PM
I suppose it's possible then that the exposed purple wire touched a heatsink and shorted out the cap. I would replace the cap, tape up the purple wire, and hope for the best. This time it might be best to take some readings with a multimeter before you plug anything into the ps.
Your ps looks different than the ones I've been working with. On the last few that I've converted, I've actually taken the board out and unsoldered all of the extra wires and removed them from the case. Really cleans things up on the inside.
P2gee 06-10-2011 09:29 PM
Originally Posted by nitro_mt_racer (Post 9238793)
The blown cap is the result of another problem. ........
Blown cap is probably the result of this power supply sitting around unused for years on end. Capacitors (especially electrolytics) do not take well to inactivity. Powering them up after extend non use sometimes results in their blowing their little brains out as your picture shows. This can also result in high voltage AC appearing where it shouldn't be.
cm367700 06-11-2011 07:43 AM
that might be the problem since I bought this power supply at a small computer shop
