imax b6 charger help >
Old 05-27-2011, 04:28 PM
Default imax b6 charger help
so i have the imax b6 charger to charge my lipo batteries. it works great but i have a problem.
i have a 8000 mah lipo battery but the charger has a capacity limit of 5000mah
so when the battery reaches 5000 mah it stops charging.
is there any way to change this setting so i can fully charge the battery?
i have searched google and the owners manual with no luck
Irok the 40s is offline
Old 05-27-2011, 09:26 PM
Trader Rating: 21 (100%+)
In User Set Program, there's a capacity cutoff. 5000mah is the default, Navigate to that parameter and increase it as needed.
It's covered in the manual, I found a copy here (was slow to dnload) -
http://www.astecmodels.co.uk/pdfs/Imax-B6%20manual.pdf
Duster_360 is offline
Old 05-27-2011, 09:29 PM
oh i must have overlooked it because i was in a rush to get the battery charged ha
thanks for your help
