no brakes on a 3pk
Old 05-25-2011, 01:24 PM
Trader Rating: 25 (100%+)
Default no brakes on a 3pk
hello, i've tried different models, reset models, and can't get any brake throw on the servo. switched to another 3pk and it has brakes. am i missing something or is it screwed like i think?
ohiofordfan is offline
Old 05-25-2011, 01:50 PM
Did you check the EPAs.
There is a servo monitor function which shows the travel, have you used it?
Also check throttle speed the low side may be turned off.
Did you try a fresh setting that wasn't used before?
Check to see if any of the brake functions are inhibited and check to see if the throttle trim is centered also the subtrim.
AreCee is offline
Old 05-25-2011, 02:15 PM
JayL's Avatar
check the ATL, it is on a dial and people hit it all the time
JayL is offline
Old 05-25-2011, 02:16 PM
i checked the trims and epa's. i didn't know about throttle speed and the servo throw thing. will check these out and post back.
Old 05-25-2011, 03:38 PM
throttle speed was ok. servo monitor shows very little brake movement. went to adjust and did the throttle. now it's fixed, works great. i have no idea how that could have been messed with. you never know with 11 year olds. thanks for the help.
