-   -   Lipo Discharge Rate quiry? (https://www.rctech.net/forum/radio-electronics/516916-lipo-discharge-rate-quiry.html)
speed6 05-25-2011 03:48 AM
Dear all,
i will be connecting in parrallel 3 x 11.1 Lipo rate at 20C discharge rate.
Since they will be in parrallel would i have a typical discharge rate close to 60C?
thanks
crusey_aus 05-25-2011 04:33 AM
When connecting in parallel you simply add their capacities
3 x 5000 mah 20c 3s packs becomes a
15000 mah 20c 3s pack
Cheers
speed6 05-25-2011 08:24 AM
noted with thanks
Duster_360 05-25-2011 09:01 AM
Wiring does not change a lipos discharge rating.....
What you see is the impact of effectively running a much bigger pack when wired in parallel.
If you're charging these 3 in parallel, its likely you've been doing that wrong too if you don't understand that paralleling effecting forms a larger battery by adding capacities.
