Smallest power supply
So far this is the smallest power supply I have found. I don't ever charge more than two 2s packs at 5 amps even though they can handle more.
Is there anything out there smaller? |
What power output does your charger have ?
To charge a 2s pack at 5 amps requires a charger with a 42 watt output Cheers |
I have 250w chargers, but what does it matter? I'm looking for small power supplies.
If your only concern is size, your best bet might be searching eBay for a laptop power supply that fits your needs.
Originally Posted by pakk
(Post 9151142)
Laptop PSU brick will not be able to supply 250w for you chargers... |
THat's not true. If you have a 250W charger, but your only using 50W, then that's all your power supply needs to provide.
Just because you have a V8, doesn't mean you HAVE to drive it at 150 all the time! |
I don't ever charge more than 5amps on 2s lipos x 2. So all I need is 10 amps. I'll look into the laptop PS deal.
Thanks |
Originally Posted by JR007
(Post 9151417)
(Post 9152145)
Thanks |
I have two chargers. Both of which are charging at 5 amps on 2s packs each.
.....now back on topic. I'm looking for a small power supply. I'm not trying to show off my chargers. Has anyone used/converted a laptop PS? They seem to be outputting in the range of 18v+, 6 amps, and 100+ watts. They seem to be good enough for 1 charger, but not two. But they are also very small, so having two might not be an issue. |
I use a converted 800w server power supply with a 8"x3"x3" footprint with three sets of bullet connectors and it powers my charger, my sons and a friend that shares a pit space with us with no problems after a year of using it. Don't know how small your looking for but maybe a 500w or 600w computer power supply would be worth looking at.
I use a cheap 12v 5A power supply
.http://www.hobbypartz.com/acadfortht6c.html I guess its 7.5A, but I dont care. Ive been using it with this charger for ever and its never had any issues! At least 100+ charges, discharges, etc http://www.hobbypartz.com/60p-dyc-1004.html I charge 2s, 3s, 4s up to 5 amps. Everything stays cool. For under $40 Im happy. |
(Post 9155105)
.....now back on topic. I'm looking for a small power supply. I'm not trying to show off my chargers. Has anyone used/converted a laptop PS? They seem to be outputting in the range of 18v+, 6 amps, and 100+ watts. They seem to be good enough for 1 charger, but not two. But they are also very small, so having two might not be an issue. http://www.huntkeydiy.com/UserFiles/...main/1000_.jpg Very high quality, not 100w but 90w though, 5.2A max at 15-16V. Good luck. |
That seems to be the route I'll be going. I'll just have to run 2. I'll keep looking around and I'll see what I come up with. Thanks everyone.
Here is one you could run bouth chargers off of. Case Dimensions: 194mm x 95mm x 54mm (60mm tall with 4 rubbers on bottom)
http://www.hobbypartz.com/77p-g350-powersupply.html And a couple of converted power supply threads. I have not yet tried any of these! Thanks to those that created them to use. Anyway: http://www.rctech.net/forum/radio-el...r-supplys.html http://www.rc-monster.com/forum/showthread.php?t=27554 http://www.rcgroups.com/forums/showt...8#post17023400 Hope these help Mark |
| All times are GMT -7. It is currently 12:10 AM. |
