-   -   vxl 3s problems (https://www.rctech.net/forum/radio-electronics/514360-vxl-3s-problems.html)
imoto228 05-17-2011 03:02 PM
vxl 3s problems
1 Attachment(s)
i just baught a vxl 3s esc and the wires comming off of the brushless motor do not fit into the female ends of the wires in the esc, the wholes are to big. is there sopossed to be someting in there? HELP!
Stuntbikemike 05-17-2011 03:08 PM
Should fit...:confused:
imoto228 05-17-2011 03:11 PM
it doesnt... the male end is to small...:(
Duster_360 05-17-2011 04:08 PM
The vxl motor comes with 3.5mm bullets, so the vxl-3S ESC is setup for 3.5mm bullets.
There should be females on the esc so you're saying that the motor you're trying to use has bullets that are smaller than 3.5mm?? You can either change to the matching size bullets on the motor, change the bullets on the esc to match the motor or get a set of adapters in the right size - something like these -
http://www3.towerhobbies.com/cgi-bin...?&I=LXPHD9&P=7
I use the adapters so when I sell a motor or esc, it has the orig bullets still installed on it.
