-   -   Minimum TX Voltage Spectrum DX3S? (https://www.rctech.net/forum/radio-electronics/513498-minimum-tx-voltage-spectrum-dx3s.html)
Jake C6R 05-15-2011 08:57 AM
I'm sure this is here somewhere but couldn't find it. Where do you guys set your low voltage warning on the TX for the DX3S? Is the 5.0V default setting fine? 90% of 6V would be 5.4V so it seems running it down to 5.0V might be a little low? Thanks!
Now that I think about it if you use rechargeables you will only be at 4.8V so I guess a 5.0V low voltage warning for alkalines is probably fine?
