Novak New Big Motor
Having written about the latest Ballistic 8 and Ballistic 8L brushless motors from Novak back in January, the Irvine California based company has revealed of images of the final product. Designed to fit into 1/8th scale buggies, truggies and monster trucks, these 550 size motors offer plenty of power with the long version providing even more torque. Novak is also developing a compatible speed control called the Kinetic 8 Racing Sensored Brushless ESC. More information will be announced for this new ESC as it becomes available.
http://www.teamnovak.com/password/no...tic8_225px.jpg The Ballistic 8 motors are not only larger in size, but mighty in features too! Each motor boasts: • 4-pole magnet, 12-slot hand-wound stator, rebuildable sensored design • Exclusive, adjustable mechanical timing • Two sizes available: Ballistic 8 (43.5 dia x 71mm); Ballistic 8L (43.5 dia x 76.5mm) • Multiple bolt patterns and sizes • 4-pole, high-strength Neodymium rotor • Widely spaced (35 deg), extremely heavy-duty solder tabs • 5mm x 18mm Output Shaft—Compatible with Novak's Mod 1 and 32-Pitch Pinion Gears • Available in several winds, including 1.0Y and 1.5Y • Designed to ROAR specifications • Compatible with sensored and sensorless speed controls • Designed, assembled and tested in Irvine, California Source: teamnovak |
Where's the Havok8?
After the HV products, i'm done with Novak stuff.
| All times are GMT -7. It is currently 07:17 AM. |
