-   -   Mamba Max driver problem... (https://www.rctech.net/forum/radio-electronics/510824-mamba-max-driver-problem.html)
Bugger234 05-07-2011 06:10 AM
I want to manually program my Mamba Max ESC, so i plugged it into my computer, after i installed the castle link software, and tried to install the drivers for it... I even found the folder in the program files that contains the drivers, but it doesn't want to recognize these files. I've even followed the directions from the castle link url about drivers, but it doesnt seem to work. Any PC gurus out there that can help me? :p
Duster_360 05-07-2011 09:06 AM
What operating system is on your PC, XP, Vista, W7, etc?
Metalsoft 05-07-2011 09:27 AM
When you go to castle files folder, are you using the setup.exe file. This is a executable file for the drivers.
It does depend what OS you are running. If it is a 64-bit OS, then you might have to install it in compatibility mode, or make sure it goes in the (x86) program files folder.
Is it giving you a error, or just will not work?
Yosh70 05-07-2011 10:46 AM
What do you mean, installed the software and then install the drivers?
If you installed the Castle link software correctly (right click "run as Administrator") then the icon should be on your desktop. Hook up the USB cable to your PC and ESC and click on the icon. The Castle software boots up and the connection status turns green.
