-   -   spektrum + hobbywing problems (https://www.rctech.net/forum/radio-electronics/510157-spektrum-hobbywing-problems.html)
getloose 05-04-2011 08:43 PM
ok, so i have a losi 8ight-E with a hobbywing 80A esc and a spektrum DX3E radio.
i just got a secind reciever so i plug it into the car and im having trouble, neutral is full throttle, no steering. thats where it is now, before i still had no steering, and neutral was like 10% throttle.
i have tried to reset the esc throttle points to no avail. i feel like its worse now.
can anyone help put me on the right track to getting this setup working correctly?
etivac13 05-04-2011 08:58 PM
something like this happened to me when i changed radio... i had to recalibrate the esc(HW 150A) with the new tx/rx... problem solved...
nadan805 05-04-2011 09:06 PM
You could bind the new RX with a different power source, then recalibrate the ESC.
Robs Pics 05-04-2011 09:30 PM
If you are not getting any steering whatsoever, it looks like you first need to bind the receiver to the transmitter. Did you do that yet?
getloose 05-04-2011 09:48 PM
binding the receiver was the first thing I did.
i think im just going to take it into the lhs tomorrow and have them sort it out, they've helped me with it when i first got the car.
latemodel13 05-05-2011 05:22 AM
Receiver
I would check the order you have the servo and ecs wires plugged into the receiver. That's the only thing I can think of unless the speedo is bad.
getloose 05-05-2011 06:11 AM
doubt the speedo is bad since it was working perfectly before i swapped receivers.
