-   -   savox servo? (https://www.rctech.net/forum/radio-electronics/509950-savox-servo.html)
tomfish 05-04-2011 07:59 AM
savox servo?
will I need to run an external BEC if I hook it up to my Castle SCT/sidewinder esc?
Also what about the same servo with a Novak GTB?
trying to avoid using BEC's if possible.
AreCee 05-04-2011 08:03 AM
You didn't specify which servo.
Regardless you do not need to use an external BEC in most cases but you may find that you may need a receiver capacitor if the servo pulls too much power from the ESC's internal BEC.
redbarton 05-04-2011 08:42 AM
If you're using a Savox digital servo, there is a strong chance the capacitor won't be enough. I started there and it helped, but didn't cure all the problems I was having. In my opinion, get the BEC and save yourself the effort. This goes double if you are using Castle and Spektrum stuff together.
tomfish 05-04-2011 08:43 AM
thanks, yes savox digital 1258
