HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 12-24-2012, 12:40 PM
  #1471
Ok thanks
mrsnake is offline
Old 12-25-2012, 08:07 AM
  #1472
pballer2777's Avatar
Trader Rating: 28 (100%+)
So I'm going to get 2 esc one for my scte and one for my 1/8th buggy. My question is will the sc pro work for the 1/8th or should I spend the few extra $ for the 150a? Also for the scte I have a novac ballistic 4.5 motor, will this motor work with the sc pro?
pballer2777 is offline
Old 12-25-2012, 09:08 AM
  #1473
d_scientist's Avatar
Hi hobbywing,
I've got this motor here :
How to i remove the blackpart with the cable (because i would like to solder the cable from the esc directly to the motor to look like this)
d_scientist is offline
Old 12-25-2012, 10:07 AM
  #1474
BillyT.'s Avatar
You can't. Those wires go straight to the windings. Easiest to run the motors wires straight to the ESC.
BillyT. is offline
Old 12-25-2012, 10:43 AM
  #1475
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
He's right! you mess with the wires the motor will not function and you'll blow your warranty!
BlackStarRacing is offline
Old 12-25-2012, 08:05 PM
  #1476
its setup like this now... real messy!
any advise?
Old 12-25-2012, 08:09 PM
  #1477
Trader Rating: 21 (100%+)
I'm just starting to use the sc pro for 1/8. After all it is spec'd for 1/8 buggy.
mulepic is offline
Old 12-25-2012, 08:31 PM
  #1478
Kevin_M's Avatar
any advise?
I have the same setup on my e buggy and have same issue with wires looking all messy. I dont have any suggestions for you but I hope someone can help. Id like to hear as well.
Kevin_M is offline
Old 12-25-2012, 08:37 PM
  #1479
I think the connectors that are used for connecting the esc and the motor are very very long while the cables on the esc are too long too...
I've seen direct soldering of cables to the motor but maybe its not this motor. a ezrun possibly??? *confused*
Old 12-25-2012, 08:39 PM
  #1480
rallyredevo is offline
Old 12-25-2012, 08:44 PM
  #1481
Originally Posted by rallyredevo
You can shorten the esc wires as well and put new bullets on it. I had the same problem with my 1:8 buggy but just left the esc wires long. Stupid hard-wired wires suck but you can't beat the price.
any suggestion for a good bullet that would suit the 150A esc/motor?
Old 12-25-2012, 08:52 PM
  #1482
Old 12-25-2012, 09:01 PM
  #1483
Castle 6.5mm should be the best as far as current handling but not sure how 12awg fits them. I didn't necessarily mean get different bullets I just meant new bullets because they might be a mess if desoldering old ones so easier to use new ones.
erm... i think the problem lies in the lenght of the damn bullets and not the width (correct me if I'm wrong, a 6.5mm bullet means its width is 6.5mm across the circle rite?)
Old 12-25-2012, 09:08 PM
  #1484
Unhappy
Originally Posted by COBRARACING
Hi Guys
This thread will be used for tech support and setups for hobbywing product for off road applications .you can request software etc and talk about anything you like with r/c .
thank you for your time
regards Angelo
Can modify XERUN 150A FW for support auto detect 4S 5S 6S lipo?
mosfet is offline
Old 12-25-2012, 09:13 PM
  #1485
Vegatron75's Avatar
When I'm using a motor and esc that doesn't have solder posts or tabs, I'll just cut the wires to the length I want, then solder the them together.
Less solder joints than bullets and neater.
Vegatron75 is offline
