HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 03-08-2024, 05:37 PM
  #13861
RetroThutmose's Avatar
zeroed out my transmitter and it is working like normal
RetroThutmose is offline
Old 03-11-2024, 11:48 PM
  #13862
wsl
Default LCD Program Box with XR8 Pro G3
I am having problem with LCD Program Box (HW310_v2.1, version PB-4.0.09) with XR8 Pro G3. stuck at "Connecting ESC". Does anyone know are they compatible?
wsl is offline
Old 03-19-2024, 12:47 AM
  #13863
gigaplex's Avatar
Originally Posted by gigaplex
G3 or G3S? My G3 works fine. I've updated my G3S firmware and same issue.
They've just released another new firmware, 4.4.03 and it's fixed the neutral range issue. There's also another firmware, 4.4.03-G3 which is oddly named, not really sure if I should try installing it to see what it does.
gigaplex is offline
Old 03-21-2024, 10:57 PM
  #13864
Also posted in the other thread..
I picked up an XR10 Justock ESC / G2.1 17.5T motor combo from my LHS last month, and I was quite surprised to see in the fold-out manual that there's no cut-off protection.. is this a concern?
If I buy the LCD Program Box, would that allow me to set a voltage cutoff to 3.6v per cell?
Feijai is offline
Old 03-22-2024, 12:09 AM
  #13865
gigaplex's Avatar
Not sure what that fold-out is on about, that ESC has a low voltage cutoff.
gigaplex is offline
Old 03-22-2024, 07:35 AM
  #13866
Is it set by default though? This is what I'm referring to:
Apologies if I'm asking the wrong thing, I've just been reading about which ESC to get, and the GensAce battery thread says I shouldn't go lower than 3.6v per cell.
Feijai is offline
Old 03-22-2024, 08:54 AM
  #13867
DirkW's Avatar
The manual says how the default settings are marked right under the table (although they should have said "in bold and italics"). So the default is 2.6V/cell, according to that manual and you cannot set 3.6V per cell, maximum is 3.4V/cell.
gigaplex likes this.
DirkW is offline
Old 03-22-2024, 02:17 PM
  #13868
gigaplex's Avatar
Odd that the default is 2.6, the manual for mine says it defaults to 3.2. But your picture clearly shows that the default has it enabled.
Are you sure you have the XR10 Justock? Your image shows a setting for brushed vs brushless. That ESC doesn't support configuring for brushed. Nor does it support timing.
gigaplex is offline
Old 03-22-2024, 05:59 PM
  #13869
Bigedmond's Avatar
Trader Rating: 20 (100%+)
Search on my phone is horrible. Is there a part number for the power switch case for an XR8 plus G2. I had the switch in a bad place and it cracked and would like to just replace the power switch case.
Bigedmond is offline
Old 03-23-2024, 11:14 AM
  #13870
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
anybody know what the potential problem ROAR had with the new torque rotor for the G4R series?
RC*PHREAK is offline
Old 03-24-2024, 08:52 PM
  #13871
Thanks @gigaplex. Ran into someone at the track with the Hobbying Programmer Box and he set my cutoff to 3.4V, also gave me reverse with the ESC and changed the burst setting,.
My daughter was happy the second half of today driving with reverse.
Feijai is offline
Old 04-04-2024, 03:15 PM
  #13872
Anyone tried to run high voltage packs on the G2S elite? I'm talking 8.7v from the pack.
Sabin is offline
Old 04-07-2024, 01:39 PM
  #13873
Fidanza's Avatar
Trader Rating: 23 (100%+)
I have a new Hobbywing XR10 Pro Legacy Edition and when I try to put the esc in calibration mode the led flashes red and the esc makes a constant beeping sound and nothing happens. Servo doesn’t not work either. All the connections look good. Never had this problem before.
thank you for your help.
Fidanza is offline
Old 04-07-2024, 04:24 PM
  #13874
gigaplex's Avatar
It's supposed to beep like that until you press the button again with the throttle at the right positions. If the servo isn't working that suggests either something is not plugged into the receiver correctly or the BEC is dead in the ESC (or maybe the receiver isn't bound to the radio).
gigaplex is offline
Old 04-10-2024, 12:00 PM
  #13875
Hi, is it possible to configure the BEC voltage to 6V without any external programming device?
On Xerun XT10 pro.
Smarley is offline
