HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 10-27-2023, 04:39 PM
  #13816
Tractagator's Avatar
Originally Posted by shortcut3d
What is the bearing size for the Hobbywing Xerun V10 G4? The website states 9x4x4 and 8x3x4. These would be very uncommon RC brushless motor bearing sizes. I believe the first digit should be the middle digit, but want to order the correct size.
The G4 is not listed on the site for replacement bearings. Can these be owner replaced?
Yes, I got them through acer
Tractagator is offline
Old 10-27-2023, 09:49 PM
  #13817
There arenít any 9x4x4 or 8x3x4 bearings through Acer. So I assume the correct size is 4x9x4 and 3x8x4
shortcut3d is offline
Old 10-28-2023, 04:43 AM
  #13818
Sorry, yes you are correct
Old 10-31-2023, 05:33 PM
  #13819
1900 kv g3 motor lost power and gets really hot, when spinning the shaft it doesn't give me much resistance. Does this mean my rotor is toasted?
bratan is offline
Old 11-01-2023, 05:12 PM
  #13820
OffRoadJunkie's Avatar
That sounds like your rotor is toast. No resistance when spinning the shaft means the magnetism, of the rotor, is really weak.
bratan likes this.
OffRoadJunkie is offline
Old 11-02-2023, 07:44 PM
  #13821
Thank you! Thought about Bocca Orange Seals, but went with Acer Ceramic bearings.
I also picked up a set of titanium screws.
I watched a couple V10 G4 tear downs and it looks like itís not shimmed very much. Specifically, the sensor board has no shims. Is there a way to improve the sensor deviation?
Old 11-02-2023, 08:01 PM
  #13822
Not sure. We gave up on stock and went mod.
Old 11-03-2023, 07:05 PM
  #13823
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
On the G2S with the build in fan cage.....is there a nice way to remove that cage...or even replace the top half of the ESC. I wish I had gotten the elite. This cage is annoying
Wildcat1971 is offline
Old 11-03-2023, 08:15 PM
  #13824
gigaplex's Avatar
No
gigaplex is online now
Old 12-12-2023, 01:27 PM
  #13825
I have older Xerun 120A V3.1. What is good setup to start? 2WD 8.5T Hobbywing V10 motor.
Pushead is offline
Old 12-13-2023, 02:01 AM
  #13826
Hello all,
i am new to elo so sorry for my questions. I bought a MBX8TR Truggy and a hobbywing XR8 G3 Pro ESC with a 4274 2250kv engine. No i read that this Motor is not
allowed to use with this ESC!! Is that correct? Or did the esc need an update?
Michael
Holymoly is offline
Old 12-13-2023, 08:55 AM
  #13827
I read the same thing, so I swapped ESC's around.
Fastfred1952 is offline
Old 12-29-2023, 04:01 PM
  #13828
Anyone else seeing that the Android Hobbywing Link V2 app is not working? Several complaints in the Play store in last few days about this.
Bicycle019 is offline
Old 12-29-2023, 06:07 PM
  #13829
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Yup. It opens and then immediately closes on my phone running android 14.
CCristo is offline
Old 12-29-2023, 07:21 PM
  #13830
gigaplex's Avatar
Won't launch on my phone at all right now. Worked fine about a week ago.
Edit: Just attached to my Android debugger and captured this exception:
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.hobbywing.hwlink2/com.hobbywing.app.MainActivity}: java.lang.SecurityException: com.hobbywing.hwlink2: One of RECEIVER_EXPORTED or RECEIVER_NOT_EXPORTED should be specified when a receiver isn't being registered exclusively for system broadcasts
Looks like the app isn't using the correct flags when registering the listener.
