HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 03-24-2023, 06:07 PM
  #13741
gigaplex's Avatar
Originally Posted by Geo_ologist
So I think I accidentally fed power into the xr8 pro esc's programming port.
I had a battery plugged into my multifunction lcd programming box,(7.2 receiver lipo that I was using to check the function of the box) I wasn't thinking and I plugged the box into the esc. Now the esc won't power on when plugged into my battery (the proper way). The fan comes on and I get a blinking light if I plug the esc back into the program box with battery.
I can hook the program box with battery to the esc and plug it into the computer and the computer recognizes the esc. So I don't think the esc is completely fried.
Any advice?
Sounds like you fried the BEC.
gigaplex is online now
Old 03-24-2023, 06:47 PM
  #13742
That is what I feared. Though on others I've fried the bec it would at least turn on. The fact I can still adjust it on the computer is odd.
Geo_ologist is offline
Old 03-24-2023, 07:43 PM
  #13743
gigaplex's Avatar
The computer/program box is probably powering the controller.
Old 03-24-2023, 09:19 PM
  #13744
Thats exatly what is happening.... so anybody ever cracked one of these open and bypassed the bec?
Old 03-24-2023, 09:27 PM
  #13745
gigaplex's Avatar
You won't be able to bypass internally, you still need a regulated power source. You might be able to use an external BEC but I'd either be sending it in for repair or just replacing it.
Old 03-24-2023, 09:30 PM
  #13746
So essentially the BEC can only handle the voltage one way. Since I applied too much on the output side of the BEC (program port) it causes issues.
Old 03-25-2023, 02:28 AM
  #13747
gigaplex's Avatar
Correct. It's an output, never feed voltage into that port.
Old 03-25-2023, 05:19 AM
  #13748
Yeah I wasn't thinking. I knew better.
Oh well. Live and learn.
Old 03-25-2023, 08:12 AM
  #13749
So I cut the switch off the perhaps blown esc to use on another I had with no switch. Well.. that esc wouldn't power on. So on a hunch I grabbed another switch I had kicking around in the parts bin and twisted it I to the wires of the "blown" esc. Now I can connect the program box with zero issues and it reads. Lights come on the esc and everything. Is it possible that a blown switch saved the bec?
Old 03-25-2023, 03:42 PM
  #13750
gigaplex's Avatar
I wouldn't have thought so but your evidence suggests otherwise.
Old 04-06-2023, 10:14 AM
  #13751
RC10Nick's Avatar
bit of a silly question, but is it possible to flash a boost timing firmware onto a justock ESC? The track I race at just switched the buggy class from 17.5 to open and there's one particular jump I just don't have enough motor to clear. I figure the cheapest way to get a little more power is just boost the 17.5 I have rather than buy a new setup.
RC10Nick is offline
Old 04-06-2023, 07:01 PM
  #13752
gigaplex's Avatar
No.
glennhl likes this.
Old 04-07-2023, 02:02 AM
  #13753
DirkW's Avatar
If there was, this whole ESC would become pointless as people would immediately start cheating.
gigaplex likes this.
DirkW is offline
Old 04-07-2023, 08:32 AM
  #13754
RC10Nick's Avatar
what? no it wouldn't. it would be just like any other firmware that only goes into blinky mode when all boost timing is disabled.
RC10Nick is offline
Old 04-07-2023, 08:53 AM
  #13755
DirkW's Avatar
The whole point for the Justock is that timing is impossible on it so that you don't have to look for blinking lights and quite a few classes depend on that ease of teching.
DirkW is offline
