HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree180Likes
Old 12-28-2022, 07:32 AM
  #13726
vr6
Trader Rating: 22 (100%+)
Originally Posted by gigaplex View Post
Commenting on the video makes more sense, since that's where you were getting your (mis?)information from.
there are numerous questions people have asked and he has not answered, so I brought up the discussion here
vr6 is online now
Old 01-04-2023, 08:55 PM
  #13727
Just read that xr8 g2s and xr10 g2s are in supported list. Would you have a try?
If it works, i will get myself a set for sure.
https://www.hobbywing.com/en/products/info.html?id=94
stranger0429 is offline
Old 01-05-2023, 04:06 PM
  #13728
Easy and surefire way to tell the stock spec V4 from the previous versions?
Silverbullet555 is offline
Old 01-06-2023, 01:23 AM
  #13729
gigaplex's Avatar
The previous version has 3.1 in large font on the side. The latest should have XR10 instead.
gigaplex is offline
Old 01-22-2023, 05:02 PM
  #13730
Hopefully simple question(s)…XR10 Stock Spec…how do you select the 5 preset modes? Do you need the lcd programmer to do it? What preset mode is the factory default mode? They refer to them as “easy to select” presets…but then they aren’t specific about how to “easily select them” LOL.
PS I’m an electric noob, have only run nitro, this is my first brushless electric setup.
JGSpeed is offline
Old 01-22-2023, 11:11 PM
  #13731
Yes you do need LCD programmer or wifi module or OTA programmer. If you can read and have manual it tell you default settings.
FolioHattu is offline
Old 01-23-2023, 03:46 AM
  #13732
I have the manual and I can read, but I don’t see where it tells you what the default settings are, and by default settings I mean the settings the esc is set to from the factory. Can you please show me where?
JGSpeed is offline
Old 01-23-2023, 04:08 AM
  #13733
With programmer you can do factory reset to esc and you can see default settings. Previously in manuals default settings was darken.
gigaplex likes this.
Old 01-23-2023, 09:38 AM
  #13734
I knew I wasn't crazy, it's no longer indicated in the manual like in the past. Here is the response from Hobbywing Tech Support:
Hello,
Unfortunately they are no longer "highlighted" in the manual like they were in previous generations so the only way to get them is to connect a programmer and review them. The default "profile" is #1
We have put in a request to get the defaults listed, but it will be some time before that happens.
FolioHattu likes this.
JGSpeed is offline
Old 02-15-2023, 01:27 AM
  #13735
RockinTheCasbah's Avatar
For off-road with the xr8 g2s, are people running the zero or off-road profile ? Off-road profile like like it's softening the bottom then adding turbo and boost, and hads a different brake frequency. Usually when you addbesc timing you change gearing and drop a tooth or two on the pinion . Has anyone played with the profiles in 1/8 issue and found gearing changes needed to be made ? Or any issues running the off-road profile?
RockinTheCasbah is offline
Old 02-17-2023, 05:59 AM
  #13736
So... my last xerun pro sct died, which over time I have been replacing with xr8 sct escs which I have found out are being discontinued. What is hobbywing suggesting as a replacement that fits both the form factor and 4s capabilities that the xr8 sct satisfies?
Geo_ologist is offline
Old 02-18-2023, 11:09 AM
  #13737
G2s 550 4 pole and 1/8 buggy truggy
XR10 G2 Legacy 540 4 pole
There's no budget choice anymore
Old 02-24-2023, 05:59 PM
  #13738
Tophe7d's Avatar
Default OTA programmer no longer working?
My OTA programmer will not stay connected to my new/used XR10 pro. I tried resetting the module, restarting the ESC, uninstalling and reinstalling the app... I even tried connecting it to my other XR10 Stock Spec (that it worked with before) and it wont stay connected to that either??? The module will find and connect to the ESC, but once I try to check parameters, it says cannot load and breaks the BT connection (icon). The only thing that has changed is it was last connected to a HW esc in a mini-z and it worked fine. Now, not so much. Feeling very frustrated at this point. Please advise. Thanks.
Tophe7d is offline
Old 02-25-2023, 05:07 AM
  #13739
Hi have you tried this yet? From what I’ve read support is coming in a future release, which probably means never or in the next version of the ESC. Futaba also have to add something to their firmware as well first I believe.
Cynan is offline
