HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree174Likes
Old 09-06-2022, 04:14 PM
  #13696
fifi's Avatar
Originally Posted by gigaplex View Post
Have you checked the obvious stuff like ESC calibration or a binding drivetrain?
Reset and calibration was done. Drivetrain is free.
Originally Posted by Nahoj View Post
I had the same issue after updating the firmware. Think it is a bug. I adjusted the driving frequency one step lower (from 8k to 4k I think) and then the dragbrake was to normal again.
Thanks I will try.
I will try also with another motor.
UPDATE I found the issue, trim for the gaz was off.
fifi is offline
Old 10-04-2022, 08:48 PM
  #13697
Default Where did the smoke come from?
Welp, I did the reverse polarity thing…. XR10 Pro Stock Spec 2S with the smaller Non-Polarity Capacitor Module. Briefly made contact, heard a pop, saw the dreaded magic smoke, wires got hot…. Feared the worst, but all still seems to be working. I haven’t been able to test the cap module, but is there any chance that saved the ESC?
Cromulent is offline
Old 10-05-2022, 12:25 AM
  #13698
No… hobbywing will sell you a replacement at a savings.
LAGuy is offline
Old 10-05-2022, 02:49 AM
  #13699
gigaplex's Avatar
If anything that non polar cap made it more likely the ESC fried. My guess is it blew a FET and looks like it works but won't run at optimal performance.
gigaplex is offline
Old 10-10-2022, 09:23 PM
  #13700
D1Rk's Avatar
Strange issue with my Xr8 SCT pro & g3 1900kv motor in my hb e819rs. Never had issues with it over heating until yesterday at the track randomly between packs. No hard landings, no corroded junk wiring. I can't figure it out. Ambient temps are low too. Green light flashes. Card reader reads the esc at 210+ after about 1 minute of run time.
D1Rk is offline
Old 10-18-2022, 07:47 AM
  #13701
Tophe7d's Avatar
Not sure if this is in the right place, but just in case you haven’t already checked, HW recently released an update for their BT module. I, like most, had no connectivity with my older Android phone (Galaxy S8… Stop laughing! =D)
After the update, it now connects with no problem.
Hope this helps.
Tophe7d is offline
Old 10-19-2022, 07:01 PM
  #13702
Did you check that the ESC fan was running? I had the same issue in an 819rs. The servo arm came back and hit the fan and caused it to fail. That caused the esc to overheat. I replaced the fan and mounted the ESC further back to make sure it didn't get hit by the servo arm.
0010 is offline
Old 11-05-2022, 04:12 PM
  #13703
fmimages's Avatar
Default Motor clicking sounds
I just got the 60a ESC and I soldered the motor wires up but maybe I got something wrong as I am trying to calibrate it but on the first step I get a motor clicking sound. Wire B should be fine maybe the other two are reversed. I get a click sound in the drivetrain so I stop. Questions?
fmimages is offline
Old 11-05-2022, 04:13 PM
  #13704
Joel Lagace's Avatar
Post detailed pictures of your install. All wiring.
Joel Lagace is offline
Old 11-05-2022, 05:07 PM
  #13705
fmimages's Avatar
fmimages is offline
Old 11-05-2022, 05:38 PM
  #13706
fmimages's Avatar
fmimages is offline
Old 11-05-2022, 06:17 PM
  #13707
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
To me it looks like you have the A & C motor wires swapped. That won't work with a sensored ESC.
From memory, all of my HW ESC's have the motor phases in the order of A, B, C from left to right when looking at them straight on. They need to go to corresponding tabs on the motor, which are normally the same order.
PDR is offline
Old 11-05-2022, 07:27 PM
  #13708
Also it appears the sensor wire is not plugged into the esc?
Old 11-07-2022, 10:43 AM
  #13709
fmimages's Avatar
Thanks.... I'll look into it.
fmimages is offline
Old 11-07-2022, 01:28 PM
  #13710
gigaplex's Avatar
The ESC will have the phases labelled.
gigaplex is offline
