HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
Fellas, is xr8 sct enough for 2200kv in 1/8 buggy?
Yes. We run that same setup in our truggies.
Did a search and can't find the correct answer. Tore 2 4268 gen2 motors apart to check bearings. 1 motor had 1 brass shim and 1 crush washer, the other had 2 crush washers only. What's the proper shim setup? I assume the crush washer goes on the pinion end and the brass shim is supposed to be on the sensor board end?
I see a lot of drivers (including pros) using ONLY 1 degree of boost in their set up sheet. Not 0, not 5 or 10. But 1. I don't see how it can have an effect on the car.
Can someone explain why? I am new to the hobby. Thanks.
Believe me....1° of boost has a good effect on bottom end punch! It also depend on how the boost is applied.
Also some drivers only properly update their car sheets (some not even that 100%), not necessarily their ESC's sheet.
If running a xr10 stock spec esc on a 17.5 2wd buggy will I need to get the programmer ? What will the benefits be ?
Pros and cons against the justock version?
Serch youtube (eliminate hobbywing esc button not working )
Is there a way to program a xr8 pro without a programmer? I need to switch the motor direction (sensored motor) and don’t have a programmer. The instructions show a chart but only show access with a programmer.
https://www.hobbywingdirect.com/pages/download
You can use any USB to servo adapter, I use this one here:
https://www.ebay.com/itm/28269504352...4AAOSwDxFZ4yEY
Yes you can download the USB Link software here for free:
cool. thanks.
Also can anyone explain what exactly does "softening" do?
Softening reduces timing for the set conditions. However, with softening activated, you're no longer in blinky mode.
