HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-27-2021, 03:53 AM
  #13516
Hi Folks
I have a SC-8 speedo .
the other day I was running car when battery goes flat. I replace battery but the speedo dont work.
The servo is fine .....But only get constant green light on speedo and no response.
Any idea whats wrong ?
Fencer39 is offline
Old 06-29-2021, 03:19 PM
  #13517
Quick one. Xr10 pro.
I upped the voltage of the bec to 7.4 for my hv servo. All works but I notice that the fan also spins faster.
Hadn't noticed this on my xr8 plus or xr8 sct.
I guess this is because the fan is off the bec too...just want to confirm though.
Skynet5 is offline
Old 07-01-2021, 04:58 AM
  #13518
gigaplex's Avatar
That depends on the ESC and where you've plugged the fan in, but yes this is expected. Some ESCs won't increase the voltage to the program/fan port direct on the ESC, some do. If you've plugged the fan into the receiver it'll definitely spin faster.
gigaplex is offline
Old 07-01-2021, 02:47 PM
  #13519
Ok. The fan is just plugged into the dedicated fan port on the ESC with the xr10 pro. I presume the fan is not just a 5v fan and will handle the extra volts.
Skynet5 is offline
Old 07-01-2021, 03:58 PM
  #13520
​​​​​​Read the manual. Fan operates at bec voltage.
Skynet5 is offline
Old 07-03-2021, 08:20 PM
  #13521
Thestoutdad's Avatar
Default Hobbywing Max10 Sct and Castle 1512 in a losi Lmt?
I just bought a losi lmt builders kit. Waiting for it to arrive. I have a Max10 sct esc laying around and I got a great deal on a castle 1512 motor. Bullets on the motor are too big but I can easily solder 4mm bullets on it. Everything specs wise looks kinds ok between these 2. Wanted some more experienced peoples opinions. Thanks!
Thestoutdad is offline
Old 07-05-2021, 01:15 PM
  #13522
Trader Rating: 16 (100%+)
I have some Justock XR10's along with a couple of Stock Specs. When I hook them up to the Programmer Box and then to my computer, the USB Link shows the correct description for each adjustable item. However, I just got a 1S Pro Heavy Duty (Mod) Hobbywing ESC and the descriptions do not line up with the proper item number. For example, under Brake Frequency it gives the description for Boost Timing. I tried upgrading the firmware to the latest and it's still all screwed up. Anyone else notice this and is there anything I can do to fix it?
glennhl is offline
Old 07-07-2021, 05:59 PM
  #13523
i have an XR10 pro that just stopped sending power to the motor, but the servo still turns, is it a dead esc? or do i need to get a program box and maybe reset it?
bradlee1212 is offline
Old 07-08-2021, 02:21 PM
  #13524
Check solder joints and sensor wire first.
Skynet5 is offline
Old 07-08-2021, 02:24 PM
  #13525
Nineball's Avatar
Quicrun 10bl120 cutting out: is it because 120A isnt enough for a 4.5T or is the BEC too weak?
Nineball is offline
Old 07-11-2021, 05:20 PM
  #13526
Is there any literature / screenshots / youtube videos showing me in depth about the data logging?
I was looking at a Castle because I like what they have for the data logging, would like to see how the HW stacks up.
gigaplex likes this.
Adam007 is offline
Old 07-12-2021, 07:24 AM
  #13527
Tractagator's Avatar
Is the Hobbywing 1900 kv motor(30401906) ROAR approved? From what I can tell off of ROAR's site, it isn't.
Thanks!
Tractagator is offline
Old 07-15-2021, 03:14 PM
  #13528
Thanks!
If that is the g3 model. Then no it isn't.
Skynet5 is offline
Old 07-15-2021, 04:32 PM
  #13529
Correction. Just seen liverc update. Go for it
Skynet5 is offline
Old 07-15-2021, 05:30 PM
  #13530
It was like a soap opera down here....
Skynet5 likes this.
